I agree with that.  What we're talking about here is engine failure due to preignition/detonation/knocking however you want to term it.  It is a function of several things but in the end, its all pressure and temperature and the fuel suceptibility (based on characteristic such as octane rating) to combusting unpredictably under these conditions.  And 115F cylinder head temperature is not the magnitude of temperature we're talking about here but more like +2000F combustion flame temperatures.
While static compression ratio is certainly one design factor in making forced induction work, its only one part of the picture. Dynamic compression (includes static compression as well as cam timing and inlet system pressure drop, or rather in this case pressure rise) and compressor characteristic of the turbo or supercharger and any intercooling are all part of that equation. Definitely much more involved than the compression ratio rule of thumb.
