These were from an open track day at E-town.
A ton of seat time ( i stopped early as I was literally just tired). Its a very tight technical track (aside from the ungodly long straight), with alot of off camber turns and late apexes.
The track is beat up though, pretty bad. They need to spend some money and fix it up. But for $125 and basically unlimited seat time you can't beat it.
It was so bad that both me and the Miata I was going back and forth with most the day ended up with chippedwindshields from pebbles.
The pics were from the Miata's drivers friend, so thus why we're always in them together. I couldn't really compete on the real tight turns with him, but over the entire track we were pretty equal in lap times. I would put legnths on the straights and I actually out braked him (carbotech XP10's and Cobra R Brakes work awesome!)
We had some different ideas about which lines to take, and unfortunatly the correct line which I took most the time was beat up so bad with pothols or bumps it would slow you down worse than the wrong line.
Either way a Blast, heres pics and links to the Vid from the Miata. (i'm in front of him for the first couple minutes)
Here you see me taking the correct line, and the Miata going way wide, however right at the apex there is a bad bump, your front left wheel looses traction and you have to let off everytime you hit it. This track would be great if they would just repave it
Video Link : You see how I kill him on the straights, and even through the high speed sweepers and the awesome 16 degree banked turns. But in the slower off camber turns he reels me in quickly.. Just two totally different cars with two totally different types of weapons!
