I installed this set-up myself in about 40 minutes without a jack. All you need is a socket wrench with 13MM and 11MM sockets, and an 11MM open end wrench. You re-use the rubber hanger isolators from the stock exhaust. I also have the Corsa X-Pipe on the car. This system has a unique sound, on the exotic side, and has a real nice howl when winding up through the gears. There is a notable increase in power as well. No drone at cruising speeds.
