I just started my comp vsr stage 2 cam install this afternoon(Thanks Jared). I didn't get to far, just removed the valve covers, then spent another 2hrs figuring out how to use the spring compressor tool.:smash:
I rented one from Freedom performance, it has 2 shoes, 1 larger that will sit over the retainers, and one smaller one for follower removal.
This is going to take a lot longer than expected. Have to get used of the tool, still haven't got one thing off yet. I only worked on it for about 3 hrs, but that included doing some valve cover decorating
Should move along once I get the hang of using the tool. Had to buy a compression tester adapter so that I could air up the cylinder so I don't drop a valve. Also need to order new cam phaser bolts, the 3 dealers I called around here wanted $30 a piece and were special order. So my new ones will be here thursday from Brenspeed and hopefully a tune also from them will be ready.
I will be working on it tomorrow afternoon again.
I could bitch about it, but it is actually fun
I will keep you guys posted and try and snap some pics.
