Thread Tools | Display Modes |
#16
How long does the smoke last? How about for the V6?thanx
| Sponsored Links |
#17
10 minutes for the heavy smoke, but it'll smoke a little during a hard start or WOT for a few days. I made the mistake of revving it in front of the garage the next day and got black shit on the garage door.... Oops
__________________
PI swapped, LT's, O/R H, Pro 5.0, 24lb injectors, FRPP 4.10's, sniper SF w/ AEM WB on column, MMFLSFC & Steeda UDP ![]() 253.x/292.x dyno #'s w/ me tuning 13.41@104.76
#18
I heard that you can pour the sea foam with the engine oil? and also pour in your fuel tank? is that correct? I would like to make sure before i do it. thanx
#19
Um No, definitely don't do that. You suck it in with the vacuum lines...
__________________
#20
check out this call on youtube to the seafoam rep.
#21
Nice find!^
__________________
#22
X2!
#23
the first time i had even heard about it what when i stumbled upon the first video with the white stang. i would definately do it but i would make sure someone who has done it before is there too lol
__________________
![]() Eibach Pro-Kit Springs BBK Cold Air Intake Smoked Single Halo Projector Headlights
#24
Seafoam is multi purpose. If you are planning on doing an Oil change wiht in a hundred miles yes you can add it to the oil, it is like an engine flush, and yes you can add it to the gas, its liek any other fuel system cleaner. On my 95 Tbird i would put half of the seafoam in the break booster line, and the rest in the tank, and every 4 months put a whole bottle in the gas tank, not much smoke came from the exhaust after a while from doing the seafoam every year,
__________________
#25
how old is this post
__________________
| Bookmarks |
| Sponsored Links |
| Thread Tools | |
| Display Modes | |
| Tags |
| how to, seafoam |
