How to make foglight stay on w/ high beams 94-04 - New York Mustangs - Forums
New York
Mustang Club
NY Mustang Forum Join
Mustang Club NY
Go Back   New York Mustangs - Forums > Specialty Tech > Write Up's, How To's, Installation / Uprgrade Info
Register Garage FAQDonate Mark Forums Read
Thread Tools Display Modes
  #1
Old 01-18-2009, 12:45 AM
ponycrazy2002's Avatar
ponycrazy2002 ponycrazy2002 is offline
Professional Member
ponycrazy2002 has no status.
Casino Cash: $11598
NYM Trader: (1)
Member Photo Albums
Cool How to make foglight stay on w/ high beams 94-04
On all 94-04 GT & Cobra Mustangs, when the high beams are activated, the foglights immediately turn off. This is a function implemented from the factory. Outlined below are the steps necessary to have your foglights stay on when your high beams are activated in any 94-04 Mustang.
Materials Needed:
# 16 gauge wire approximately 2.5” in length ($4.24 for a 12’ roll)
# Two male spade connectors ($3.14 for a pack of 4)
# Electrical Tape ($2.09 for a roll)
# Wire Strippers
# Needle Nose Pliers
Preparing Jumper (fake relay):
# Take your 16 gauge wire and strip off approximately ½” of the plastic sheathing on both ends.
# Crimp the two male spade connectors at each end of your 16 gauge wire with your pliers. Wrap any exposed wire with black electrical tape.
# This completes the fabrication of your jumper.
Step 1:
# Open the cover on the fuse box located underneath the hood and remove the relay using needle nose pliers.
Step 2:
# Once the relay is removed, you will notice five different open slots. The male connectors at each end of your jumper must be inserted in the two outermost slots.
Step 3:
# Insert your jumper (fake relay) in the two outermost slots.
Step 4:
# Finally, finish your installation by closing the cover on the fuse box. You are now done!
You should now be able to turn your high beams without having the foglights cut off.
_____________________________________________
2002 Mustang GT auto
MAC exhaust
K&N Drop in filter
http://www.freewebs.com/ponycrazydrivers
  #2
Old 05-31-2009, 02:38 AM
1990_LX's Avatar
1990_LX 1990_LX is online now
Clubhouse Moderator
1990_LX is hatched yet again!
Casino Cash: $31868
NYM Trader: (1)
Member Garage
Default Re: To to make foglight stay on w/ high beams 94-04
If you want them to stay on with the parking lights, just use the ignition power lead that is in the convertible top switch harness under the consul next to the fog light switch
Jeff...1990 LX 4 Banger
  #3
Old 05-31-2009, 02:42 AM
Professional Member
Casino Cash: $11598
NYM Trader: (1)
Member Photo Albums
i dont have a convertible
MAC exhaust
K&N Drop in filter
  #4
Old 09-02-2009, 01:18 PM
IRSmart IRSmart is offline
Pulling up to the line
IRSmart is probably at work
Casino Cash: $1225
NYM Trader: (0)
you don't have to have a convertible, the wiring harness is still there. but the problem is, ford redesigned the center console in i think 01 or so. they moved the fog light switch up next to the trac off and rear defog switch, under the radio. it's no longer next to the vert switch, so that mod won't work on later new edge mustangs.
i'll be doing this myself probably tonight. i have an 99/01 cobra front end, so the upgraded fogs and the high-beams are going to be perfect when i'm driving alone
4.30 gears, 15k miles, $125 shipped
37 piece spray gun kit, NIB, $80 shipped
2 trunk blackout kits, sold together, $25 shipped
Pm me for details
  #5
Old 09-02-2009, 01:20 PM
1990_LX's Avatar
Clubhouse Moderator
Casino Cash: $31868
NYM Trader: (1)
Member Garage
I should have said it's for the SN-95 cars.
  #6
Old 09-02-2009, 02:56 PM
302N20 302N20 is offline
Spinning the tires
302N20 has no status.
Casino Cash: $2753
NYM Trader: (0)
Default Re: How to make foglight stay on w/ high beams 94-04
Hell ya, I tapped my convert harness for my fogs. I drive around with parks and fogs all the time, i love the way it looks
1995 Mustang GT 306 H/C/I w/ spray
Ross Forged pistons, Trickflow Stage one cam, Edelbrock Performer 5.0 170cc with 1.90 intake valves, ported gt-40 lower, Tubular gt-40 upper, T-5 with astro gears, 3.73s, Edelbrock wet shot
408w coming in 2010....
  #7
Old 09-02-2009, 03:02 PM
Casino Cash: $1225
NYM Trader: (0)
Quote:
maybe they changed how they were wired, but i can drive with my parking lights and my foglights now, and i haven't yet modified anything
Pm me for details
  #8
Old 10-03-2009, 11:59 AM
Casino Cash: $1225
NYM Trader: (0)
So I attempted this mod tonight with negative results. The how to isn't clear enough. It doesn't say whether you need to be modding the FOG LIGHT relay or the FOG LIGHT BYPASS relay. Both have 5 spade holes in them. So I tried the FOG LIGHT relay. I inserted the fake relay into the holes and my fog lights turned on without the knob being pulled, so I'm like well, that's not right lol. As I was removing the fake relay, one of the spades touched my strut tower bar and sparked like a mother. Now my fogs won't turn on. I don't see a fuse for the foglights, just the FOG LIGHT and FOG LIGHT BYPASS relays. Everything else still works just fine. The bulbs themselves are fine. I checked them to make sure they didn't blow in the surge. The FOG LIGHT BYPASS relay was installed at the time of the spark, so is it possible that the surge ruined the fog light bypass relay? after the spark, i reinstalled everything back to stock. when I try to turn the fogs on, I can hear the fog light relay clicking on, and the indicator light inside the car is on, just no fogs. HELP!
Pm me for details
  #9
Old 10-03-2009, 01:01 PM
Casino Cash: $1225
NYM Trader: (0)
to correct, the relay i'm talking about is actually called the FOG LAMP INTERRUPT, not FOG LIGHT BYPASS
Pm me for details
  #10
Old 10-03-2009, 01:11 PM
Professional Member
Casino Cash: $11598
NYM Trader: (1)
Member Photo Albums
the fuse or relay is blown. you might also wanna check the high beam fuse to make sure
MAC exhaust
K&N Drop in filter
  #11
Old 10-03-2009, 02:13 PM
Casino Cash: $1225
NYM Trader: (0)
guy on corral figured it out, i popped the #27 fuse (DRL, fogs). can you take a picture of the exact relay and slot position so that i don't blow myself up?
Pm me for details
  #12
Old 10-07-2009, 05:24 PM
brklynzturk04's Avatar
brklynzturk04 brklynzturk04 is online now
Stepping on the gas!
brklynzturk04 has no status.
Casino Cash: $2330
NYM Trader: (0)
Member Photo Albums
1 got a 98 cobra..can some one please tell me how to have the foglights on with the parking lights
  #13
Old 10-20-2009, 01:10 PM
Casino Cash: $1225
NYM Trader: (0)
i take it that's a no-go on the pic of the fuse box?
Pm me for details
  #14
Old 10-21-2009, 11:55 PM
fiveohhfox's Avatar
fiveohhfox fiveohhfox is offline
Bronx Regional President
fiveohhfox is FoMoCo 4me MoFo
My Mood:
Casino Cash: $12425
NYM Trader: (0)
Member Photo Albums
fog wit parks sickkk
"If "NISMO" stands for Nissan Motorsports, does that mean "HOMO" stands for Honda Motorsports? OWNED haha
  #15
Old 10-22-2009, 12:53 AM
Wicked Xtreme's Avatar
Wicked Xtreme Wicked Xtreme is online now
Super Moderator / Member Plus
Wicked Xtreme is getting by
My Mood:
Casino Cash: $29300
NYM Trader: (1)
Member Photo Albums
Member Garage
Quote:
Wire in a relay between the fogs and parking lights. If you want to switch them, feed the relay from the switch going to the parking lights then from the fog switch to the relay, from relay to fogs.
Or just tap the feed to the parking lights to the relay, and go to the fogs. when the parking lights go on, the fogs will also.
Bookmarks
PROBLEM! hole below gas pedal causeing throttle 2 stay wide open! Chuckie B 1996 - 2004 2V 4.6L V8 6 06-15-2009 03:59 AM
High RPM between shifts ryan2009 V6 Mustangs 5 06-12-2009 06:12 PM
Idling High.. SubZero00GT SVT Cobra & 03 / 04 Mach 1 4 05-07-2009 06:54 PM
High performance cams? mustangfan V6 Mustangs 12 05-02-2009 10:28 AM
stay away from Zack McGrath _bones Clubhouse 1 03-13-2009 07:49 PM
Tags
None
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
New York Mustangs is not affiliated with Ford Motor Company and is not responsible for the content added by members.
New York Mustangs, Inc. © 2010
