How to install a Ram-Air / Cold Air Intake - New York Mustangs - Forums
New York
Mustang Club
NY Mustang Forum Join
Mustang Club NY
Go Back   New York Mustangs - Forums > Specialty Tech > Write Up's, How To's, Installation / Uprgrade Info
Register Garage FAQDonate Mark Forums Read
Thread Tools Display Modes
  #1
Old 05-09-2009, 09:58 PM
MineralGray02K's Avatar
MineralGray02K MineralGray02K is online now
Admin
MineralGray02K is ready for spring
My Mood:
Casino Cash: $27353
NYM Trader: (6)
Member Garage
Default How to install a Ram-Air / Cold Air Intake
How to install a Ram-Air / Cold Air Intake on a Ford Mustang GT
SN-95 Ram Air/Cold Air
a corral original article Scott Winger
This article explains how to install an effective Cold Air and Ram-Air set-up on your Modular Mustang. It was originally written by my good friend, Nine-Ball, an engineer from Houston and installed it on his 96GT(now a Formula owner - shame on him?). I installed this on my Cobra and now have added pictures and part numbers which will assist the install and provide more detailed information for the Cobra owner. This article is a combination of Tony’s original notes and my own.
There are after-market units that you can purchase but NONE of the ram-air units will perform anywhere near as well as this modification. Plus none can be purchased for $20 (Ram-air) or $5 (Cold-air).
Tony produced an effective ram air system for his 96GT. This install is MUCH easier to do on the GT than on the Cobra because of an “Air-box” unit which is in the fender on the Cobra. Anyway, Tony searched every aisle of the local Builder's Store and finally found something of use! It came in the form of 1.2 foot long, 5" diameter four-joint aluminum sheet pipe. Basically it is dryer and furnace ducting. It has four connected pieces which can rotate a full circle at their joints. Each section has about a 22.5 degree shape. This means, if you turn the joints a certain way, you can end up with any angle between 0 and 90 degrees. This is NOT the corrugated flex tube, but the smooth material.
Picture 1 shows 3 of these pieces plus a reducer (also needed).
Needed: (the part #s and descriptions given are for Home Depot stores) For Ram Air:
  1. Your old air silencer and factory air box. (free)
  2. Some 1/4 inch long sheet metal screws (1/8 dia) ($1.50)
  3. Four sections of the above mentioned duct ($1.71 each)
    part # 0779387041448…. 5X90 GAL EL
  4. One 5" to 4" reducer. Same material as above ($2.75 )
    part # 0779387087897……5X4 GALV
  5. (Cobra only - optional on GT) One 6” to 5” reducer ($2.95)
    part # 0779387087927……6X5 GALV
  6. One piece of Screening 2.5’ long X 8” wide ($2.50)
    part # 0049821852801….Gutter guard
  7. Drill and small drill bit for screws.
  8. A hacksaw (to trim snorkel)
  9. Removal of factory fog lights (for Ram-Air)
  10. Keep factory fog lights (for Cold-Air induction)
  11. Pliers or wire cutters
  12. One cylindrical clamp 6” size ($.50)
    sorry no part number
For Cold-Air induction:
The only part needed is the 5” to 4” reducer and one piece of the 5” ducting.
Here we go!
Put the front end of your car on jack stands (safety is first).
Remove the airbox/silencer/filter from your car (for room to work). On the Cobra you also need to remove your Strut Tower Brace (if you have one), and remove the MAF and inlet tube leading to your throttle body.
Separate the silencer and airbox (if this has not been removed yet), Just pull it apart!
Cut back the factory air silencer about 6 inches from the snorkel end (see picture 2) . this will make the diameter large enough to fit over the 4" end of the 5 X 4 reducer (it stretches - make it tight). Tony and I used a hacksaw. Cut the snorkel approximately where the picture has the white line.
Picture 2 Shows the Air Silencer and Cut line
The aluminum 4" end of the 5 X4 reducer should be bent slightly in an oval shape to fit inside the oval air silencer hole. Make sure to cut the hole so that it is parallel to the line of the fender. You may have to install the silencer and mark it to be sure. Once it is trimmed to the right size, attach it to the 4” end of the reducer. Remember that the snorkel goes over-top of the 4” end of the reducer, not the other way around. Now that you have it fitting together perfectly, take the snorkel back off from the reducer and set it aside for later.
Attach three sections of the 5” ducting together (or use 1 section if you are doing cold-air induction only) , and use 2 screws in each to secure them. Then attach to one end, the 5” to 4” reducer, again using 2 screws. It’s easier to put the screws in if you drill a tiny hole first.
Now from under the car, stick this entire piece up the fender (4” end first) and into the hole leading into the engine compartment (where the snorkel used to go), shaping the pipe as you go will help here. Also, get a friend to help from above. This step is not that difficult on the GT, but it is EXTREMELY difficult on the Cobra because there is a unit called an “Air-box” that is smack dab in the middle of where you want to go, mounted at the top of the fender. It has a couple of hoses coming out of it that feed the catalytic converters on start-up. It is very tough to get the ducting past this unit, but since I did it (all by myself) I’m sure anyone else can too. Patience helps big time! Gee, didn’t SVT know we wanted to put 5” ducting in there??? LOL. The next picture illustrates basically how the ducting will route itself through the fender. You won’t have the large reducer on the bottom end yet, and if you are only doing cold air, this piece will obviously be much shorter.
Picture 3
Once the 4" end is through the fender, reconnect it to the air silencer, making it as tight as you can get it (the silencer should NOT be on the airbox yet) Re-attach the silencer to the airbox (saliva helps) and go ahead and re-install the filter/airbox/silencer. Because of the extra stiffness and lack of flexibility, I couldn’t reconnect the airbox to the fender wall using the supplied bolt, in fact I cut the side attachment off with the hacksaw along with the foot on the bottom of the airbox - I needed the room. You may get lucky and not have to do this. On the GT you are done under the hood, on the Cobra you now need to reconnect the MAF and then lastly the inlet tube to the throttle body. Don’t forget to reconnect the 2 sensor switches at the MAF, which you had to disconnect to remove the inlet tube. If you are doing the cold-air induction only, you are done (Just aim the tube forward & down.) and you can now relax and go for a drive (don’t forget to lower your car first, hehe).
**Note: Because of the tight fit of the silencer on the reducer, it will hold the lightweight piping assembly just fine (since all the other pieces are screwed together). Neither Tony nor myself needed any extra supports. Plus the first 90 degree bend also presses firmly against the fender, so it won't move once installed.
Remove the fog-light.
Depending on how exactly you have routed your ducting, you may be within one more piece of ducting from the fender, a little further than that , or even a little closer. Also, it’s not completely necessary on the GT to be touching the fender since there is no lip there to use as a support (there is on the cobra). Installing the 6 X 5 reducer on the GT is your choice.
Hold up the last piece of 5” ducting and the 6 X 5 reducer and see how well it fits. Once it seems to be fitting perfectly than take it back off and screw the 2 pieces together. On the Cobra you want it to fit over top of the lip of the fog-light hole. You can adjust the length of this piece if it is too long by prying out sections of the 5” ducting. You will have to pull really hard (close to the rivets) but they WILL come apart. Don’t install this piece yet.
On the GT cut a piece of the screen using pliers or wire cutters that will fit over the 6” end or the 5” end if you didn’t use the reducer, and bend it around the end. Use the cylindrical clamp to hold this screen in place. On the Cobra, cut the screen to size, than from underneath place it over the inside of the fog-light hole bending the screen around the lip. Pictures 4 and 5 show what the hole looks like on the Cobra with and without the screen. I recommend strongly using this screen to prevent stones leaves and seagulls from getting up in your filter box!
Picture 4
Picture 5
Now go back under the car and attach the last piece. Now you need to secure it with screws (this is tricky since the rest is already installed - being a contortionist will help;-). On the cobra you now need to use the cylindrical clamp and tighten it up over the screen/duct/lip/ area. I pulled the other fog-light also and installed the screen so that they would match!
Hey guess what…..you’re done.
Total installation time (not including shopping) is about 2 hours on the GT and a couple more than that on the Cobra! There is no question it pulls much harder than before, and it even sounds better. Both Tony and I have seen improvements of approximately 3/10ths in the ¼ and about 1 mph (not bad for $20 Eh). If you have any questions, e-mail me at Scott.Winger@sympatico.ca and I'll be glad to help.
I took this setup one step further on my Cobra. Since I lost the fog light I moved them both to the spoiler. Each one is dead center on each side of the license plate and just below (see picture 6). It now has the “Stocker” look. Picture 7 is owned by Dennis who followed my “Fog-light re-location” notes as well as installing the ram air as outlined. It looks amazing without the front plate (no choice in Canada).
Picture 6
Picture 7
The original wiring also reached to the new location which was a bonus. What is even better is that now the fog lights actually work! I guess because they are away from the headlights they aren’t getting lost in the rays. The GT spoiler unfortunately isn’t big enough to do this, so Tony got some after-market bulbs and used them instead. If you want the written instructions for the “Fog-light re-location” for the Cobra, e-mail me and I’ll send you the text in Word format.
Scott Winger (§cott 96Çobra)
Write-up @ Corral: http://www.corral.net/
Click image for larger version
2002 Mineral Gray GT - 421 rwhp / 378 rwtq
Vortech V-2 SQ, Comp Cams, gears, long tubes + full o/r exhaust, built rear and all that stuff
  #2
Old 08-04-2009, 12:45 PM
modularmustang's Avatar
modularmustang modularmustang is offline
Dropping the clutch
modularmustang is blaming dial-up
My Mood:
Casino Cash: $2420
NYM Trader: (0)
Member Photo Albums
Default Re: How to install a Ram-Air / Cold Air Intake
looks interesting, i'm going to try this for shits and giggles and data log and see if the air temp decreases or not.
PI swapped, LT's, O/R H, Pro 5.0, 24lb injectors, FRPP 4.10's, sniper SF w/ AEM WB on column, MMFLSFC & Steeda UDP
245/275 mustang dyno, me tuning
  #3
Old 08-04-2009, 12:52 PM
1990_LX's Avatar
1990_LX 1990_LX is offline
Clubhouse Moderator
1990_LX is hatched yet again!
Casino Cash: $31673
NYM Trader: (1)
Member Garage
I saw this some place before...seems like a godd idea and is rather cheep.....
Jeff...1990 LX 4 Banger
  #4
Old 08-04-2009, 06:38 PM
Dropping the clutch
My Mood:
Casino Cash: $2420
NYM Trader: (0)
Member Photo Albums
ok, i made her today, its generally easy to make, and cheap. Costs came out to be about 30 dollars. I lost my air silencer, so i had to buy a rectangular to 5 inch circle piece and cut it up to fit flush against it.
i was ready to shoot this idea down but i have to say it does seem to pull a little better when i got on it. temperature at the time i drove it was 82 degrees and the air temp (country roads) was at a steady 95-100 down from 105 ish from previous reads at about the same temp.
when i launched it i lost traction a little more going from 1-2. I guess I'm pleased with the results for 30 dollars worth of ducting ...
i want to take it down to lebanon valley before i go bak to school and i can tell you how she does. thanks again for the idea!
EDIT: here are some pictures:
  #5
Old 08-04-2009, 07:08 PM
bruiser937's Avatar
bruiser937 bruiser937 is offline
bruiser937 is supercharged and happy
My Mood:
Casino Cash: $7414
NYM Trader: (0)
Member Photo Albums
Member Garage
COOL!
  #6
Old 08-04-2009, 07:24 PM
Admin
My Mood:
Casino Cash: $27353
NYM Trader: (6)
Member Garage
Sounds good! Definitely post any and all results here
  #7
Old 08-24-2009, 11:29 AM
ray6628's Avatar
ray6628 ray6628 is offline
Warming up the tires
ray6628 has no status.
Casino Cash: $1397
NYM Trader: (0)
Has anyone thought about water? What happens in the rain? Did you drill holes in bottom to let water out? Just asking....
  #8
Old 08-26-2009, 02:55 PM
Jimmerz's Avatar
Jimmerz Jimmerz is online now
Jimmerz is mourning the loss of his stang.. R.I.P.
My Mood:
Casino Cash: $6505
NYM Trader: (0)
Member Photo Albums
Quote:
the pipe is not air tight to the point you cant get somthing thru the joints of the pipe.. so any water that does happen to get into it will seap out thru the jointed areas.. i was actually at the lowes in glenmont like months ago and was thinking about doing a cold air intake cob job myself.. i had decided against it thinking people would laugh at me lol.. maybe ill just do it now lol
  #9
Old 10-08-2009, 12:49 AM
97NYstanGT's Avatar
97NYstanGT 97NYstanGT is online now
NYM Sig Master
97NYstanGT is a rice killer
My Mood:
Casino Cash: $21388
NYM Trader: (0)
Member Photo Albums
i don't like the fact that you can't have fogs with it
Quote:
Originally Posted by Wicked Xtreme View Post
-Having a 10 second neon is like coming out of the closet... everyone is shocked at first, but in the end, you're still gay
Quote:
Originally Posted by Quick281 View Post
im not a fan of anything over 18
  #10
Old 10-15-2009, 03:45 PM
Dropping the clutch
My Mood:
Casino Cash: $2420
NYM Trader: (0)
Member Photo Albums
i uninstalled it, i liked my fogs better
  #11
Old 11-02-2009, 06:59 PM
BKD198221's Avatar
BKD198221 BKD198221 is offline
Professional Member
BKD198221 has no status.
Casino Cash: $10000
NYM Trader: (0)
Member Photo Albums
Member Garage
this is my old ram air........
BRIAN
gt 40 tubular intake ,bbk shorty headers,o/r h pipe,flows,3"tips,ported t/b,70mm maf,cold air,a/c smog delete,sub frame conn,tower brace,.....3:55 gears,
  #12
Old 11-02-2009, 10:38 PM
Aetos's Avatar
Aetos Aetos is online now
Looking forward
Aetos has no status.
My Mood:
Casino Cash: $5695
NYM Trader: (0)
Member Photo Albums
This actually something similar that they do on Trans Ams and its proven to get a small amount of gain, nothing major, so I'm guessing the same would hold true for these cars, same similar principle and design. Very very few people have had any water problems, and these people were driving through storms that most people wouldn't dream to take our cars through.
"You look like you're doing 100mph just standing still"
  #13
Old 02-22-2010, 12:46 AM
booby's Avatar
booby booby is online now
booby is cant wait to get his car back!
Casino Cash: $5770
NYM Trader: (0)
Member Photo Albums
Member Garage
what about debris? leaves and what not?
Bookmarks
Upper and lower intake install... BKD198221 5.0 Mustangs 18 08-10-2009 03:28 PM
How to install Upper Intake Plenum 99-04 MineralGray02K Write Up's, How To's, Installation / Uprgrade Info 0 05-09-2009 09:54 PM
Any recomemdations on a cold air intake? johnocch 2005 - 2010 3V GT 24 04-22-2009 09:40 PM
MAC Cold Air Intake For 96-04 Mustang GT ThePope Exhaust 5 03-09-2009 09:28 AM
How To Install a Cold Air Intake (CAI) on your Mustang GT MineralGray02K Write Up's, How To's, Installation / Uprgrade Info 0 01-20-2009 11:26 PM
Tags
air, cold air intake, how to, install, ram
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
New York Mustangs is not affiliated with Ford Motor Company and is not responsible for the content added by members.
New York Mustangs, Inc. © 2010
